| Are 51s going to work - Holley JEtting https://slantsix.org/forum/viewtopic.php?t=15349 |
| Author: | relic-lover [ Sun Dec 11, 2005 11:03 am ] |
| Post subject: | Are 51s going to work - Holley JEtting |
I am tying up the last of the odds and ends before the first attempt to start my 170 - I want to see it run am I wondering if I need to re jet the Holley carb before I try to start it up. The Holley is the 390 cfm 8007 - I believe it comes with 51 jets. This motor has a clifford M260 cam (which is almost a stock grind) and a HyperPak manifold. I know I will want to change the jetting, accelerator pump cam, and power valve later - but will the out of the box setup on the 8007 get me through the motor start up and cam break in ( 20 min at 2000 rpm plus) |
| Author: | DusterIdiot [ Sun Dec 11, 2005 12:07 pm ] |
| Post subject: | It should... |
51's seem to be OK just drove my out of the box 8007 today above the 2000 rpm level (you might have problems with the idle settings and the transition circuit). good luck, -D.Idiot |
| Author: | HyperValiant [ Sun Dec 11, 2005 6:40 pm ] |
The 8007 worked fine for my 170 HyperPak out of the box. HyperValiant |
