| crossmember use in 904 to a833 conversion https://slantsix.org/forum/viewtopic.php?t=15390 |
| Author: | flight704 [ Wed Dec 14, 2005 4:00 am ] |
| Post subject: | crossmember use in 904 to a833 conversion |
1970 dart slant six I am pulling the 904 out and putting in an A33 4spd. Will i have to get another x member for the tail shaft mounting point??????? I can make one custom if necessary. just need to know if i need to gather the stuff or if the factory auto xmember will do it with or with out modification I did a search on this and I know it can be done. It didnt adress my specific question about the cross member thanks |
| Author: | Charrlie_S [ Wed Dec 14, 2005 6:08 am ] |
I'm pretty sure the trans X member is the same. |
| Author: | SlantSixDan [ Wed Dec 14, 2005 8:41 am ] |
Yep, it's the same. What I'm not sure of, though, is if there are different-length tailhousings for the 833 as there are for the automatics. I bet there are! |
| Author: | dakight [ Wed Dec 14, 2005 10:06 am ] |
http://www.bigblockdart.com/tech/bbody4 ... ndex.shtml |
| Author: | slantzilla [ Wed Dec 14, 2005 11:45 am ] |
Quote: Yep, it's the same. What I'm not sure of, though, is if there are different-length tailhousings for the 833 as there are for the automatics. I bet there are!
The trans mount is in the same place on the auto, no matter what tailshaft length. If he has an A-body 833 the original crossmember will work. If he has an E or B body he will have to fabricate for shifter clearance. |
