It is currently Sun Nov 15, 2026 10:16 pm
PostPosted: Wed Dec 14, 2005 4:00 am
1970 dart slant six
I am pulling the 904 out and putting in an A33 4spd. Will i have to get another x member for the tail shaft mounting point??????? I can make one custom if necessary. just need to know if i need to gather the stuff or if the factory auto xmember will do it with or with out modification
I did a search on this and I know it can be done. It didnt adress my specific question about the cross member
thanks
dont compromise customize
boost IS a substitute for cubic inches
PostPosted: Wed Dec 14, 2005 6:08 am
I'm pretty sure the trans X member is the same.
PostPosted: Wed Dec 14, 2005 8:41 am
Yep, it's the same. What I'm not sure of, though, is if there are different-length tailhousings for the 833 as there are for the automatics. I bet there are!
PostPosted: Wed Dec 14, 2005 10:06 am
http://www.bigblockdart.com/tech/bbody4 ... ndex.shtml
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Dec 14, 2005 11:45 am
The trans mount is in the same place on the auto, no matter what tailshaft length. If he has an A-body 833 the original crossmember will work. If he has an E or B body he will have to fabricate for shifter clearance. :shock:
