It is currently Sun May 10, 2026 7:31 am
 Post subject: new bearings
PostPosted: Sat Dec 17, 2005 2:34 pm
ok i have new axel with green bearings for my 8 3/4 does anyone know if i need to remove the axels seals before i install them or do they just slide on behind them?
PostPosted: Sat Dec 17, 2005 5:09 pm
If you didnt get new ones with the axles then dont pull them you do need them. When I changed over to green bearings the axle seals cam with the bearings.
