Slant Six Forum https://slantsix.org/forum/ |
Does anyone actually make a new 2 barrel intake manifold? https://slantsix.org/forum/viewtopic.php?t=15834 |
Author: | Ice Titan [ Thu Jan 19, 2006 9:25 pm ] |
Post subject: | Does anyone actually make a new 2 barrel intake manifold? |
From all the potential problems with used manifolds and the various offerings on ebay, I'm beginning to wonder if brand new might be a better viable option. I've gathered that 1 barrel are a plenty. And the options for aftermarket are all four barrel from what I've read. Any ideas? |
Author: | Pierre [ Thu Jan 19, 2006 10:03 pm ] |
Post subject: | |
The clifford manifold can be mated either with a 2bbl or 4bbl adapter - both availible directly from clifford. Or, you can make your own out of scrap aluminum or anything else you may have laying around. I'm not sure if offy has a 2bbl adapter availible. |
Author: | Slant Cecil [ Fri Jan 20, 2006 6:09 am ] |
Post subject: | |
The Offy's flange is not open like the Clifford. I has four holes like the adapter. I have an Offy that someone crudely cut out the four holes to make it open. I'm going to clean up the hack work and use a MrGasket adapter so I can run a 2300 series Holley. I don't know of any problems with the cast iron 2bbl intakes, it's the exhaust manifolds that have cracking and warping problems. Ebay 2bbl intakes go for $50-$90. There has been at least one over $100. That's insanity! If I needed one, $25 tops is all I'd give. I have two laying around my shop, maybe I need to ebay them . The best 2bbl intakes were the MP 1piece aluminum versions on the Super Six. They give no real HP advantage, and you are stuck with the small BBD, but they do take off 15-20lbs of front end weight. Used is the only way to get them now, it's doubtful any are still on the shelves. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
