It is currently Sun Nov 22, 2026 10:37 am
PostPosted: Tue Jan 24, 2006 12:02 pm
Can anyone give me parts numbers, photos, instructions, etc, to hook up my 904 kickdown linkage with my offy 4bl manifold and Eddy 500 cfm carb? The carb is mounted east-west, tranverse to the engine. Any help will be greatly appreciated. THANKS! Reggie
Restored '62 Signet, 229 4bl, Offy intake, auto, Dual Dutra exhausts, shaved head and block, high stall converter, 1.6 roller rockers, etc.
PostPosted: Tue Jan 24, 2006 12:23 pm
Here is a picture of my linkage to my Holley Carb on an Offy manifold using Lokar's kickdown cable PN KD-2727HT: (Note a 904 specific cable, KD-2904HT is now offered, I believe the only difference is the length of the cables, but ask them to be sure)
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Tue Jan 24, 2006 6:01 pm
I bought the Lokar KD-2904 HT to use on my '68 Signet when I put the Offy on it. Right now, it's still in the org pkg.
Since then, I bought the Offy linkage kit from S.S.Org member Guy22. I may use this kit as it gives a more OEM look. It connects the carb to the stock 1bbl kickdown linkage. It only works for a N/S carb mount, not an E/W. It also looks as if it would work as replacement for a Super Six kd linkage.
Just throwing another option at ya.
Slant Cecil
PostPosted: Wed Jan 25, 2006 9:19 am
I don't know about a edl.. I just cut my stock kick down bar and welded a piece of stock to it to make it the work
