Doug & Dan; oil & water pump Q's
https://slantsix.org/forum/viewtopic.php?t=15949
Author:  GTS225 [ Sun Jan 29, 2006 6:37 pm ]
Post subject:  Doug & Dan; oil & water pump Q's
Do either of you know of any significant pros/cons concerning aluminum pumps compared to iron pumps?
I know the alu. water pump uses bearings and a bronze bushing to support the shaft, so it seems that it should have no significant problems as compared to an iron one.
I have one (used) aluminum oil pump, and it seems to have a gear mesh problem that I think is due to wear in the housing around the input shaft.
I'd like to try to shave some weight, but not at the expense of durability.
Roger
Author:  SlantSixDan [ Sun Jan 29, 2006 7:20 pm ]
Post subject:  Re: Doug & Dan; oil & water pump Q's
Aluminum weighs less.
Factory water and oil pumps were aluminum.
