It is currently Fri Nov 20, 2026 5:10 pm
 Post subject: Holley 1920 Adjustments
PostPosted: Mon Feb 06, 2006 7:52 am
I was looking through the FSM and I noticed that there is no label on the 1920 for fuel mixture adjustment screw, but there in on the BBD, at least I think there is. I'll have to double check.
Point is, is there a screw adjustment for the fuel on the 1920? If so, where the hell is it?
The old white brick
PostPosted: Mon Feb 06, 2006 8:00 am
Are you referring to the idle mixture screw? If so, it is the screw in the base of the carb on the opposite side of the idle speed screws.
 Post subject: Yep
PostPosted: Mon Feb 06, 2006 9:50 am
Yep, that would be the one, thanks Reed.
And before I forget to ask, what is the proper way to adjust it, b/c if its by smell, I'm screwed. Erm, no pun intended there.
The old white brick
PostPosted: Mon Feb 06, 2006 10:01 am
Turn the screw in until the engine starts to run rough, then turn it just starts to smooth out and you hear the rpms raise. This will get you in the ball park. The best way to adjust is get a vacuum guage, hook it up to the choke pull off vacuum port (with engine warmed up of course) and adjust the screw out until you get the highest vacuum reading.
 Post subject: And...
PostPosted: Mon Feb 06, 2006 10:42 am
...Thanks again. Another fun thing to fix up on the car.
The old white brick
PostPosted: Mon Feb 06, 2006 10:44 am
Actualy, the best way to set it is to install an O2 sensor and get a air/fuel ratio guage and set it to stoichiometric. Barring that, Eric's method is best. :wink: :P
PostPosted: Mon Feb 06, 2006 1:02 pm
What is the best way to do this on a dual 1bbl set-up?
64 Dart 170 /6
PostPosted: Mon Feb 06, 2006 1:53 pm
Start your tuning with the carbs having the mixture screws exactly the same number of turns out, then turn the mixture screw on each carb 1/8 turn at a time. Or run dual exhausts and put an O2 sensor in each exhaust line.
PostPosted: Mon Feb 06, 2006 2:23 pm
... and this proceedure would apply to a BBD as well?
VM
PostPosted: Mon Feb 06, 2006 3:38 pm
Yes! But on the BBD you can also choose to run the inboard mixture screw 1/8-1/4 turn leaner than the outboard screw, just to compensate for the orientation of the carb.
