It is currently Tue Nov 17, 2026 8:25 pm
 Post subject: HEI and Missing Wire
PostPosted: Mon Feb 13, 2006 4:42 am
I'm working on installing an HEI unit in my truck. It no longer has lean burn. Problem is the new points distributor only has one wire comming off which goes to the coil. All the diagrams I've seen show two wires from the distributor to the HEI module. What, how, where?
And what does the ballast resistor look like?
The Old Goat '83 D150 225-2
AKA Ice Titan
PostPosted: Mon Feb 13, 2006 6:18 am
To use the HEI, you cannot use the point distributer. You must use a mopar electronic distributer. The balast resister is a white ceramic part, about 1/2 inch square, about 2 1/2 inches long, with two electrical male spade connectors, one on each end. It should be mounted on the firewall.
PostPosted: Mon Feb 13, 2006 6:21 am
I'm not sure you can do this with a points distributor. My HEI setup uses the electronic distributor from a late '70's Slant Six.
The ballast resistor is housed in a long (about 3", IIRC) rectangular white (usually discolored) ceramic piece bolted to the firewall or nearby. Depending on the year, it will have two to four spade connectors.
Charlie is quicker than I am!
PostPosted: Mon Feb 13, 2006 8:11 am
I'm using NOS :D
PostPosted: Mon Feb 13, 2006 2:07 pm
Bah! And I thought this would be an easy install.
AKA Ice Titan
PostPosted: Mon Feb 13, 2006 2:22 pm
Car Model: 1962 Lancer 770
its pretty easy with the right distributor ;) You'll be good to go when you get it.
