It is currently Tue Nov 10, 2026 12:57 pm
PostPosted: Mon Feb 13, 2006 7:47 am
Hello folks,
On Nov 27 Flight704 inititated a (to me) very intersting thread about using a NV3500 tranny in his/her Dart. Good discussion with certified wizards contributing, but to me it kinda died out. Well this weekend a board wizard rang my bell and made me remember that thread with a suggestion I look at using a New Venture NV3500 (Getrag (HM290 or MG5) tranny. I was down the T5 road but suspicion a T5 may not last long in a 5300 pound vehicle.
My application is a '64 D100 with a built slant six and a 3.91 sure grip on an 8 3/4 axle set. I did the A833OD 4 speed swap, now want to try a 5 speed, but not the NP with the granny gear. Seems the NV3500 for a '00 to '04 Dodge Dakota might even bolt directly up, according to urban legend.
(1) But I haven't found the gear ratios for a 2000 3.9 litre engine Dodge Dakota 4x4 toploader ranny I picked up, and hope someone knows or knows a site to look at so I can think about the gears and their spacing.
(2) The tranny has a flange on back for the transfer case, but no transfer case came with it. Is this any problem with using it for my 2wd app?
(3) I have seen sixinthehead's in his car, but think his was a 6 cyl tranny...will the 3.9 fit a slant six, and does this then get into changing flywheel and clutch plates to accomodate the splines on the NV?
Thanks!
rock
'64d100
PostPosted: Mon Feb 13, 2006 8:25 am
Well, the forum never fails.
While not knowing answer to my flange and clutch quest's, within minutes of post a forum member sent me this site and this ratio set:
http://dodgeram.org/tech/transmission/nv3500_spec.htm
NV3500 and the narrow ratio used in 2500LD's is close to the T5 at:
1st - 4.01 1st 3.49
2nd - 2.32 2d 2.16
3rd - 1.40 3rd 1.40
4th - 1.00 4th 1.00
5th - 0.73 5th .73
Getrag Corvette
1st - 4.23 1st - 2.97
2nd - 2.53 2d - 2.07
3rd - 1.67 3rd - 1.43
4th - 1.23 4th - 1.00
5th - 1.00 5th - .71
6th - 0.79 6th - .57
best wishes to all!
rock
'64d100
PostPosted: Mon Feb 13, 2006 8:38 am
The 3.9 V6 uses the LA (small block) V8 bellhousing pattern, not the same as the G (slant-6) bellhousing pattern.
PostPosted: Mon Feb 13, 2006 12:09 pm
Dan,
Great advice, as always! I have one of AndyF's tranny adapters. Since Andy's fits the V8 automatic and will go to a 318, might it be possible to use the 3.9 with Andy's plate onto a slant six? That would be a pleasant finding!
rock
'64d100
PostPosted: Mon Feb 13, 2006 12:30 pm
An adaptor that'll put a V8 automatic transmission behind a slant-6 should work just fine to put a V8/V6 bellhousing + manual trans behind a slant-6. You may need to do some clever figuring on how to take up the extra space created by the adaptor plate.
