It is currently Thu May 14, 2026 12:43 pm
 Post subject: Lug studs for '71 Dart?
PostPosted: Wed Feb 15, 2006 3:53 pm
Hey guys- Need to replace the lug studs on my 71 Dart. Started to order them online and got confused. Apparently there are different studs for the front and back drums? Hmm. Any advice? Thanks!
 Post subject: right stud
PostPosted: Fri Feb 17, 2006 3:21 pm
Car Model: '63 Dart GT Convertible
There are different threads for the two sides of the car. I don't know when they qiut, but Chrysler used left hand and right hand threads on cars in the 60's. Might have carried into the early 70's. Check the end of the studs for an "L" or an "R". I wouldn't think there would be a difference from front to back, being as you might then have problems when rotating you're tires. Unless a difference because of mounting into the axle or drum assembly.
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
PostPosted: Sat Feb 18, 2006 3:41 pm
1970 was the last year for LH wheel studs.
Users browsing this forum: Google [Bot] and 6 guests
