Lug studs for '71 Dart?
https://slantsix.org/forum/viewtopic.php?t=16188
Author:  spare_parts13 [ Wed Feb 15, 2006 3:53 pm ]
Post subject:  Lug studs for '71 Dart?
Hey guys- Need to replace the lug studs on my 71 Dart. Started to order them online and got confused. Apparently there are different studs for the front and back drums? Hmm. Any advice? Thanks!
Author:  63gtcv [ Fri Feb 17, 2006 3:21 pm ]
Post subject:  right stud
There are different threads for the two sides of the car. I don't know when they qiut, but Chrysler used left hand and right hand threads on cars in the 60's. Might have carried into the early 70's. Check the end of the studs for an "L" or an "R". I wouldn't think there would be a difference from front to back, being as you might then have problems when rotating you're tires. Unless a difference because of mounting into the axle or drum assembly.
Author:  65 dartman [ Sat Feb 18, 2006 3:41 pm ]
1970 was the last year for LH wheel studs.
