It is currently Sun Nov 15, 2026 9:50 pm
 Post subject: Oil pump check valve
PostPosted: Wed Feb 22, 2006 8:25 pm
does anyone kno where I can get a good check valve for the oil pump. I mean the tube that screws into the base & the oil filter screws onto, w. a check valve to keep the filter from draining? my check valve broke
PostPosted: Thu Feb 23, 2006 4:07 am
I would try a Mopar dealer, call it out as an 86 SL6 truck. These have a tube that is a little shorter but the valve is the same.
Your next option is to get a used one out of a junkyard or a fellow SL6er.
PostPosted: Thu Feb 23, 2006 8:37 am
Might still be available from the Dealer, as DD says. Part number is 3577848.
PostPosted: Thu Feb 23, 2006 10:38 am
hey thanks for the help, I'm gonna check the dealer today
