| Oil pump check valve https://slantsix.org/forum/viewtopic.php?t=16293 |
| Author: | zooter86 [ Wed Feb 22, 2006 8:25 pm ] |
| Post subject: | Oil pump check valve |
does anyone kno where I can get a good check valve for the oil pump. I mean the tube that screws into the base & the oil filter screws onto, w. a check valve to keep the filter from draining? my check valve broke |
| Author: | Doctor Dodge [ Thu Feb 23, 2006 4:07 am ] |
I would try a Mopar dealer, call it out as an 86 SL6 truck. These have a tube that is a little shorter but the valve is the same. Your next option is to get a used one out of a junkyard or a fellow SL6er. DD |
| Author: | SlantSixDan [ Thu Feb 23, 2006 8:37 am ] |
Might still be available from the Dealer, as DD says. Part number is 3577848. |
| Author: | zooter86 [ Thu Feb 23, 2006 10:38 am ] |
hey thanks for the help, I'm gonna check the dealer today |
