It is currently Tue Nov 10, 2026 12:33 pm
PostPosted: Fri Feb 24, 2006 1:48 pm
I noticed last night the hose that runs to my vacuum advance on my distributor is missing. I've looked in my Chilton book but I cannot find anything showing where it would connect to. Anybody have an idea?
Thanks
Specs:
225 D100
1945 Holley
A833OD
85' D100
225cid
A833OD
 Post subject: Trick
PostPosted: Fri Feb 24, 2006 2:17 pm
There will be a small port on the base of the carb. It should have vacuum only when the trottle is open a little, but not much or any at idle.
If you get really stuck, I'll pop the hood on my wifes car and take a pic, but someone might also have a link to a diagram for you.
1980 Aspen 225 super six
PostPosted: Fri Feb 24, 2006 2:30 pm
Are you sure that your distributor /has/ a vaccuum advance? By '85 most (if not all) of the trucks had switched over to the Spark Control Computer, which had no advance on the distributor.
PostPosted: Sat Feb 25, 2006 7:11 pm
It is Stryker, to my understanding only a few were produced.
85' D100
225cid
A833OD
PostPosted: Sun Feb 26, 2006 10:36 am
In that case, take your vaccum gauge and find a 'ported' vaccum source on the carb. This is one that is taken above the throttle blades, so vaccuum actually increases with RPM. Run a hose from there to the dist. and you should be in business.
PostPosted: Sun Feb 26, 2006 1:39 pm
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Mon Feb 27, 2006 8:13 am
Thanks guys,
I hooked it up, took it for a spin but I didn't notice much of difference.
85' D100
225cid
A833OD
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
