It is currently Sat Nov 07, 2026 7:26 pm
 Post subject: Valve seats w/ OS valves
PostPosted: Wed Mar 01, 2006 6:11 pm
During my rebuild, I'm puttting in oversized valves. The head is a '78, and the original seats were still in great shape. Rather than replace what I thought was a perfectly good hardened seat, I just had them cut larger so that the new valves (1.44, 1.70) would fit. Since then I've had a couple people tell me that "hardened" seats are actually only surface hardened, and after cutting, these are no longer adequate. If this is true, where can I find the seats I need?
PostPosted: Wed Mar 01, 2006 8:01 pm
They are a little more then surface hardened, but, in general, that is true. The machine shop that does the work, should have the seats available.
PostPosted: Wed Mar 01, 2006 8:41 pm
My first good head that Mike and Blaine did just had the hardened seats ground out for the big valves. I beat the snot out of that head and never hurt a seat. It was always run on unleaded gas too.
I have been told that you are in greater danger of losing an insert than burning the ground out seat anyway. By the time you put in a standard insert and grind it out for the big valves there is not much left. :shock:
My new real race car head just has the stock seats ground out too. :lol:
Users browsing this forum: Amazon [Bot], Google [Bot] and 5 guests
