It is currently Sun Nov 08, 2026 6:40 pm
PostPosted: Fri Mar 03, 2006 6:37 pm
I read somewhere before, though of course i cant find it. That there is a carb out there that will bolt right onto a super six manifold and has electric choke. I wanna say its off of a buick. I just picked up three super six intakes at the junkyard (one alumn) and ill use one on my slant.
I didnt get the exhaust manifolds for a couple of reasons, and i know the choke work right with the 1bbl exhaust manifold...so im looking to see whats availible with electric.
Thanks
-Mike
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
PostPosted: Fri Mar 03, 2006 7:10 pm
You're looking for a carb set up like this:
The integral choke is not electric, it's a heat-tube style, but can easily be retrofitted to electric operation. The carb shown is an Australian-built Stromberg from a '70s Holden (GM).
PostPosted: Fri Mar 03, 2006 7:12 pm
Buick=probably Rochester(crap)
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri Mar 03, 2006 7:58 pm
Any thoughts on this? Supposidly a carter bbd off a later jeep with electric choke
http://cgi.ebay.com/ebaymotors/Carter-B ... enameZWDVW
74 Duster /6
PostPosted: Fri Mar 03, 2006 10:52 pm
Quick question. I can get a super six exh manifold for free from a friend of mine if i decide to use it. I know stock its 2" and the super six is 2 1/4"...right? What do you guys normally do to make your 2" bolt up to the 2 1/4"?
thanx
-Mike
74 Duster /6
PostPosted: Fri Mar 03, 2006 11:05 pm
thanx
-Mike
The exhaust manifolds are the same... Only the pipe coming off the manifold is different.
PostPosted: Sat Mar 04, 2006 7:47 am
The AMC/Jeep BBDs are highly problematic carburetors. You will spend a lot more time, money and effort trying to get one to run right (and keep running right) than you would have spent to just use the correct Chrysler carburetor with 2bbl choke unit.
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
