It is currently Sat Nov 14, 2026 2:20 am
 Post subject: I found one!
PostPosted: Sat Mar 04, 2006 4:32 pm
Today I picked up a cast iron supersix intake and a matching Carter BBD that is in excellent shape. I am watching a supersix kickdown linkage on e-bay but it has already hit $30 and has 4 days to go. I plan on boring out my stock exhaust manifold outlet so I can run a 2 1/4 pipe all the way out the back. I plan on using a Flowmaster muffler, maybe a 40 series Delta flow or a 60 series which is made for sixes. How much will this wake up my Duster over the stock 1-barrel configuration. I have 2.76 gears out back so I don't know if my acceleration is going to improve all that much. Now with the Hollely 1945 it is a dog.
By the way, does anybody know the length of the super six accelerator cable? I am eyeballing one of the stainless kits from lokar.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Sat Mar 04, 2006 5:40 pm
I believe you can just use the throttle cable from an a-body that had a V8.
Nick
1987 Dodge D-100(225/904) Daily Driver
1979 Dodge Ramcharger (318/727/NP208)(Under Construction)
PostPosted: Sat Mar 04, 2006 5:43 pm
Yeah I considered that, but I like the shiny look of stainless. Impresses the judges.
82 D150-225/727
PostPosted: Sat Mar 04, 2006 5:48 pm
Ah,I see. I must not be in the show-car state of mind,Most of my fleet looks like junk. :D
Nick
PostPosted: Sat Mar 04, 2006 5:52 pm
The fact that I can't find a throttle cable for a v-8 (2-barrel) A-body screws things up too.
82 D150-225/727
PostPosted: Sat Mar 04, 2006 7:47 pm
Jeb, like I told you, seek and you will find!
On the cable, I usually just run the original one-barrel cable, matter of fact, I'm still using it with the four-barrel on the Duster. Just put a nice sloping twist in the housing. If I was gonna spend big $$$ on KD linkage, I'd just go ahead and get the Lokar set-up.
The 2V wakes things up a bit, but it's not going to make the car a tire-boiling hot-rod. A little more top-end and a tad bit more "perky" is about it.
D/W
If it ain't broke, fix it!
PostPosted: Sat Mar 04, 2006 7:54 pm
Hey Dennis show me a picture of what you are talking about. Are you talking about the "camel hump" method?
82 D150-225/727
PostPosted: Sat Mar 04, 2006 8:11 pm
Jeb, don't have a picture handy (you can see it the somewhat Duster thread in the "slixer's gallery"), you can give it a little twist which will make it more like a "barrel roll" than a "camel hump" :wink:
I think I've sorta got it "humped up" now to get it good and away from the heat of the headers, but it was more stealthy when it was "super six" setup.
D/W
PostPosted: Sat Mar 04, 2006 8:38 pm
Maybe some judges...not this one!
 Post subject: Re: I found one!
PostPosted: Sun Mar 05, 2006 1:09 am
Very nice. I just picked up FOUR super six setups over the past two days lol. gotta love junkyards. 3cast and 1aluminum. kickdown and throttle linkage. None had carbs id want to mess with, ill keep an eye out for a good carb off a 318 van or something (van because they are a little more protected from the weather in a car thats at the junkyard) If i were you, i'd consider just a 3.23 gear swap. would be a decent little pickup off the bottom end, and highway wouldn't suffer too much.
good luck!
-Mike
Daily Driver 72 'Cuda
74 Duster /6
http:www.goodysgotacuda.com
PostPosted: Sun Mar 05, 2006 5:06 pm
Will the cable off of a M-body work? I know where there is a bunch of Fifth Avenues.
82 D150-225/727
PostPosted: Sun Mar 05, 2006 5:31 pm
Car Model: 1962 Lancer 770
Jeb honestly I'd think twice about the 40 series muffler...or you can buy mine used ;) I just found it to be too obnoxious.
MJ
PostPosted: Sun Mar 05, 2006 5:37 pm
Yeah, I think that I will go with the 50 or 60 series.
82 D150-225/727
PostPosted: Sun Mar 05, 2006 5:47 pm
Because it was too loud? sounded ricey? what was the reason?
I have super 40s on my 'Cuda and love the sound :D it is a healthy small block though
74 Duster /6
PostPosted: Sun Mar 05, 2006 5:54 pm
No, because I heard that the interior resonance with the 40 series is terrible. I am use to loud noise since our farm truck (90 F-250, 351 Windsor) has straight pipes on it. The exhaust stops right under the passenger side floorboard. At about 60 the exhaust quietens down to a burble but on acceleration it is deafining. But it does get a lot of attention (and tickets).
I want a great sound on the outside but still be able to hear my radio.
82 D150-225/727
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
