| 63 suspension rebuild possible problems https://slantsix.org/forum/viewtopic.php?t=16460 |
| Author: | sixsignet [ Mon Mar 06, 2006 1:10 pm ] |
| Post subject: | 63 suspension rebuild possible problems |
What can you do if you remove the A-arms from a 63 A-body and find that the K-member has damage to some mounting/bearing surface? I guess I'm concerned with the mount for the LCA. I'm still figuring how I am going to do this. This will be a one-man operation in a carport. This is my daily driver. I am not planning on removing the K-member for reinforcing welds. I guess I'll get upper and lower control arms from 73-76 car so I can have them ready b4 I take front end apart. If the K-frame is too damaged to use, does this escalate to pulling the engine, removing the K-frame, etc? I will have to rent a car/truck to transport the K-frame and make trips to the machine shop, but chances of finding another early 60s K-frame are pretty slim (I don't think I've seen a 60s A-body at a wrecking yard since moving to Washington). |
| Author: | dakight [ Mon Mar 06, 2006 3:18 pm ] |
All American in Vancouver and Wildcat in Sandy, OR both have numerous A-bodies and K members are interchangeable up through about 67. It should not be difficult to find. In fact, there are probably several folks on this board that have a spare or two. Shipping could be an issue but not an insurmountable one. |
| Author: | VDART [ Mon Mar 06, 2006 4:44 pm ] |
| Post subject: | suspension |
I've found the best way for your situation is get some spares ie-- upper/lower arms -- put the new bushing in them & then swap the parts-- won't have much down time . Start spraying your bolts with a rust penetrant now--- upper control bolts can be a bear sometimes-- good luck |
| Author: | Matt Cramer [ Tue Mar 07, 2006 7:14 am ] |
Just about all '62 and up A-body LCA's are interchangable, except for their sway bar mounting tabs. You don't need a set of '73-'76 lower control arms to do a disc brake conversion. I used my stock '66 LCA's. |
| Author: | HyperValiant [ Tue Mar 07, 2006 6:45 pm ] |
VDART is right.On my wifes 63 Dart,I had another set of upper and lower control arms and brake assemblys(changed to K-H disc brakes) and the tie rod ends.Every thing was painted and detailed and the swap took six hours and a string and level alignment took another hour(aligned just enough to get it to the alingment rack-and really wasnt out to much). HyperValiant |
| Author: | Dago Red [ Thu Mar 09, 2006 10:06 pm ] |
| Post subject: | Front End Rebuild |
| Author: | sixsignet [ Fri Mar 10, 2006 12:42 am ] |
Is there wear between the LCA's pivot pin and the K-frame? |
| Author: | Doctor Dodge [ Fri Mar 10, 2006 1:39 am ] |
I have some extra K-Frames if needed. DD
| Author: | sixsignet [ Fri Mar 10, 2006 9:38 am ] |
| Post subject: | my brain is caked with same road dirt on my control arms |
Hopefully when I remove the parts from the donor car I will see how the LCA, K-frame and torsion bar connect. It's too bad I will have to inspect my K-frame once I get the control arms off it, because I don't know what to look for. There has been a lot of popping and clunking for over a year, and I anticipate some damage somewhere. The 66 V8 K-frame is slightly different from the /6 K-frame, right? Will it work in a 1963 /6 without modification? If I use a 66 V8 K-frame, can I use my 63 /6 engine mount? How do you remove/replace the pivot pin for the LCA? Is it pressed into the lower control arm? |
| Author: | Dago Red [ Thu Mar 30, 2006 10:34 pm ] |
| Post subject: | Early A K-frames |
| Author: | Charrlie_S [ Fri Mar 31, 2006 4:10 am ] |
| Post subject: | Re: my brain is caked with same road dirt on my control arms |
Quote: How do you remove/replace the pivot pin for the LCA? Is it pressed into the lower control arm? |
