It is currently Sun Nov 22, 2026 9:53 pm
 Post subject: Spark Plugs??????????
PostPosted: Mon Mar 06, 2006 5:43 pm
I see there are alot of fans of NGK, Autolite and Champion. Is there a decided winner for a Slant that is hands-down the best spark plug?
I am running a Champion RV12YC. Would I be happier with something else? What would the Manufacturer and number be?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Mon Mar 06, 2006 6:21 pm
The bottom line is that it really doesn't make that much difference. I have had "bad" plugs that wouldn't run right of various brands, but never an NGK and I think not Autolite. I use NGK V-power GR-4s (stock or mid comp) or GR-45s or GR-5s (high comp).
PostPosted: Mon Mar 06, 2006 7:30 pm
I'd use either the NGK or Autolite extended tip plugs.
The Autolites are cheaper, but I think the NGK's last longer and are a slightly better plug.
The Autolite is 985, don't know the NGK number.......
PostPosted: Tue Mar 07, 2006 7:18 am
NGK ZFR5N, which does indeed seem to be a longer-lasting, better-designed plug than the Autolite 985.
These extended-nose plugs are available only for the up-to-1974 heads that take flat-seat plugs, not the '75-up heads that take taper-seat plugs.
PostPosted: Sun Mar 12, 2006 7:34 am
Both Champion RV12YC and AC Delco R45TS (!!!)works well in later heads.
Once on -78 Aspen AC´s were over 45000km (30000 miles) and still like new... even that car was a real oilburner
-66 Dart 170 2d sedan 225+3-speed+7,25
-68 Dart 270 4d 225+3-speed+7,25 my first Dodge, R.I.P
-66 Satellite 2dht 273+904+8,75 (gone)
-and others
Users browsing this forum: Bing [Bot] and 13 guests
