Spark Plugs??????????
https://slantsix.org/forum/viewtopic.php?t=16464
Author:  bwhitejr [ Mon Mar 06, 2006 5:43 pm ]
Post subject:  Spark Plugs??????????
I see there are alot of fans of NGK, Autolite and Champion. Is there a decided winner for a Slant that is hands-down the best spark plug?
I am running a Champion RV12YC. Would I be happier with something else? What would the Manufacturer and number be?
bwhitejr
Author:  Dart270 [ Mon Mar 06, 2006 6:21 pm ]
The bottom line is that it really doesn't make that much difference. I have had "bad" plugs that wouldn't run right of various brands, but never an NGK and I think not Autolite. I use NGK V-power GR-4s (stock or mid comp) or GR-45s or GR-5s (high comp).
Author:  emsvitil [ Mon Mar 06, 2006 7:30 pm ]
I'd use either the NGK or Autolite extended tip plugs.
The Autolites are cheaper, but I think the NGK's last longer and are a slightly better plug.
The Autolite is 985, don't know the NGK number.......
Author:  SlantSixDan [ Tue Mar 07, 2006 7:18 am ]
NGK ZFR5N, which does indeed seem to be a longer-lasting, better-designed plug than the Autolite 985.
These extended-nose plugs are available only for the up-to-1974 heads that take flat-seat plugs, not the '75-up heads that take taper-seat plugs.
Author:  dart -66 [ Sun Mar 12, 2006 7:34 am ]
Both Champion RV12YC and AC Delco R45TS (!!!)works well in later heads.
Once on -78 Aspen AC´s were over 45000km (30000 miles) and still like new... even that car was a real oilburner
