It is currently Fri May 15, 2026 12:45 pm
PostPosted: Mon Mar 13, 2006 2:18 pm
Can't seem to find any real info using the search feature on what size 15 in tire will actually fit in a 65 A Body (Dart wagon). I've got a set of Mirada 10 spoke wheels that I'll be using with the wagon. Original tire size was a 700-13. The closest radial size is a 185-80X13 which size-wise is about equal to a 195-60X15. The 8 in wide rim will take much bigger than that. I want to fill the wheelwells but not look out of place. Any real world experience on what actually does fit?
 Post subject: Tires
PostPosted: Mon Mar 13, 2006 5:17 pm
I to have a wagon and from what I've seen we can't run as wide of a tire as the other guys as we have seats between the wells. Kinda keeps the choices limited. As far as non-wagons go I have seen as wide as 265-50-15's.
married with more children than cars
PostPosted: Mon Mar 13, 2006 8:26 pm
A 7.00 13 tire was 25.70" diameter.
Which would be equivalent to a 205 80 13 tire which never existed.......
A 185 80 13 and 205 60 15 are equivalent diameters (24.7") not a 195 60 15.........
You're looking for a
225 60 15
215 65 15 or 205 65 15
195 70 15
185 75 15
tire to get the original diameter.
 Post subject: Re: Tires
PostPosted: Mon Mar 13, 2006 9:32 pm
I also have a Dart Wagon. While we cant go inward we might be able to go a little bit outward because the Wagons do not have the partially covered wheel wells of the sedans and coupes. I have only had this car for a month now, so I have not figured out what tires would work, but that is the first thing I thought when I saw the wheel well as compared to my 65 GT.
My cars are all gone, my new affliction is my Jeep Cherokee. I have lifted it, put some armor on it, and preparing for new gears and lockers. After that, bumpers, on-board air and a winch.
PostPosted: Tue Mar 14, 2006 6:53 am
Just like to point out there are no 15" sbp rims don't know if yours has already been converted to lbp.
PostPosted: Tue Mar 14, 2006 7:03 am
Stockton wheel can supply 15" sbp wheels. This is not an endorsement, I don't know anything about them, but they indicate in their online catalog that they are available.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Mar 14, 2006 12:07 pm
225/50-15 or 215/60-15 would be a very nice size on that rim.
PostPosted: Tue Mar 14, 2006 1:06 pm
$140 each, 2 years ago for OEM style (dog-dish)............
Found some used 14" instead...........
PostPosted: Tue Mar 14, 2006 3:49 pm
Lou - are you talking about those size tires on the Mirada 10 spoke? It's currenly got split and cracked 235-60X15s on them and looked really nice on the Mirada I had.
PostPosted: Tue Mar 14, 2006 5:26 pm
I didn't comment on the price, just that they are indeed available. :)
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Mar 14, 2006 5:36 pm
I like 225/50-15 on my Darts, although they are not "Big". 235/60s will likley fit too, but offset will have to be pretty close and you might have to do front fender lip tirmming.
