It is currently Fri Nov 27, 2026 8:10 am
 Post subject: Kelsey Hayes Disc Brakes
PostPosted: Tue Mar 14, 2006 4:13 pm
Last night I ordered thru Rock Auto 2 sets of Raybestos K-H calipers. This morning I got a call from them saying they are discontinued and NLA. The only thing they had or could get were the rebuilts from Cardone, plus there were only 2 of each side available. Needless to say I took them even though the price was considerably higher than what was posted on their site ($122 vs $101). All of the chains (Advance, AZ, NAPA) said not available. Guess everyone is doing the LBP conversion instead of redoing SBP brakes (could have gone that way but have reasons for keeping the SBP on my Valiant and Barracuda)
PostPosted: Tue Mar 14, 2006 4:20 pm
You can get 'em from Stainless Steel Brakes or from several of the early-Mustang suppliers.
PostPosted: Tue Mar 14, 2006 6:49 pm
Dan,what year Mustangs have the K-H calipersand are they a direct bolt on? I have K-H discs on both my Valiant and my wifes 63 Dart but the calipers on Dart are new($78 apeice with cores a year ago at Autozone)but the calipers on my Val were rebuilt and although they work well I would like to have a source for new.Thanks.
HyperValiant
PostPosted: Tue Mar 14, 2006 8:31 pm
'65 through '68. Same 1.64" piston bore. Same pads.
Another good question. assuming the mounting ears' location is the same (looks as if it is), it appears the calipers are only slightly different in that one of the threaded ports is located differently.
Here's the '65-'72 Mopar A-body K-H caliper:
And here's the '65-'68 Mustang K-H caliper:
The ports are visible in these photos by the green plastic plugs placed in them. It's a little late at night for me to dope-out how this port location difference would affect installation, but plumbing problems are usually not all that difficult to solve. Maybe all you'd need would be Mustang-spec transfer lines (which connect the two halves of the caliper).
Well, as I say, Stainless Steel Brakes Corp will sell you really nice aluminum ones, but be prepared to open up your wallet!
PostPosted: Tue Mar 14, 2006 8:54 pm
Thanks Dan,yeah, Ive checked on the SSB calipers----right at $500 for a pair---ouch!!!!!!
Thanks again.
HyperValiant
PostPosted: Wed Mar 15, 2006 4:38 am
Dan - Any idea of what the Mustang calipers cost? Actual availability since they were used in considerably less years than the Mopar?
PostPosted: Wed Mar 15, 2006 5:49 am
Multiple options show up on RockAuto and Napaonline. They were used on other Ford products of similar years, too, and Ford sold a ton of Mustangs and other cars with those brakes in those years, and there's a bigger demand for Ford parts than for Mopar parts, etc.
Users browsing this forum: Ahrefs [Bot] and 1 guest
