| 727 shifting pattern? https://slantsix.org/forum/viewtopic.php?t=16854 |
| Author: | WhaleMstr [ Sun Apr 02, 2006 3:34 pm ] |
| Post subject: | 727 shifting pattern? |
I know this may sound strange, but here goes... It's been a long, long time since I messed with this tranny and I forget where the gears are when I shift at the tranny? I thought all the way to the rear was Park, but I am not sure now? Later, D |
| Author: | 440_Magnum [ Wed Apr 05, 2006 3:08 pm ] |
| Post subject: | Re: 727 shifting pattern? |
Quote: I know this may sound strange, but here goes...
The gears are always inside the transmission case. Unless something breaks really, really badly. It's been a long, long time since I messed with this tranny and I forget where the gears are when I shift at the tranny? Quote:
Are you talking about the position of the lever that sticks out of the transmission case, or something else?
Later, D |
| Author: | WhaleMstr [ Thu Apr 06, 2006 9:12 am ] |
So that's where all them round bumpy things go!! Thanks!! Yes, I was refering to the position of the shift lever. I know that it is fully to the rear in park now. I climbed under and started shifting it and checking the driveline. Park - to the rear! Thanks, D Now I need another shift cable - the one I have turned out to have the top inch or so bent and it justs bends inside the shifter housing and doesn't move the shift lever back into park. |
