It is currently Mon Nov 16, 2026 10:05 pm
 Post subject: 727 shifting pattern?
PostPosted: Sun Apr 02, 2006 3:34 pm
I know this may sound strange, but here goes...
It's been a long, long time since I messed with this tranny and I forget where the gears are when I shift at the tranny?
I thought all the way to the rear was Park, but I am not sure now?
Later,
D
PostPosted: Wed Apr 05, 2006 3:08 pm
The gears are always inside the transmission case. Unless something breaks really, really badly. :D
Later,
D
Are you talking about the position of the lever that sticks out of the transmission case, or something else?
PostPosted: Thu Apr 06, 2006 9:12 am
So that's where all them round bumpy things go!!
Thanks!!
Yes, I was refering to the position of the shift lever. I know that it is fully to the rear in park now. I climbed under and started shifting it and checking the driveline. Park - to the rear!
Thanks,
D
Now I need another shift cable - the one I have turned out to have the top inch or so bent and it justs bends inside the shifter housing and doesn't move the shift lever back into park.
Users browsing this forum: Amazon [Bot] and 1 guest
