It is currently Tue Nov 17, 2026 4:27 pm
 Post subject: valvetrain
PostPosted: Thu Apr 06, 2006 1:43 pm
I am putting an early model head on a later model short block. I'm using the valve train and bolts etc. from a later model head. The rear bolt (Oil feed) does not fit. Are ther other differences that will get in the way? Also I want to use the original manifolds from the early 170 from the original car. Will there be an exhaust hook up problem because the later block is a taller 225?
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 11 guests
