It is currently Sat Nov 21, 2026 2:51 pm
 Post subject: im back
PostPosted: Mon Apr 24, 2006 2:03 pm
im back after taking Reeds advise and the tune up went smooth now that i found the procedure to tune my 85' van. My only question now is i went to set fast idle and i find that neither Haynes nor the Autozone site specifiy if i block off the ESA or not. It only mentions OSAC or vacuum advance cap off . My assuption was to cap off the ESA port and set fast idle is this correct?
PostPosted: Mon Apr 24, 2006 5:15 pm
Yes. Set the fast idle with the ESA hose plugged.
Users browsing this forum: Amazon [Bot] and 1 guest
