It is currently Sat Nov 21, 2026 2:12 am
 Post subject: Cranks and pilots
PostPosted: Fri Apr 21, 2006 8:54 am
Apparently there is a problem matching crankshaft ends to traansmissions at some point through the year models. I found the following statement that doesn't make sense to me:
The crankshafts from 1961-1968 used a small pilot 1.960 od/ 1.530 id. They were a forged casting as well. Crankshafts after 68-76 used the large pilot 2.160 od/ 1.805 id and are all forged castings.
Shouldn't "Crankshafts after 68-76" say "Crankshafts during 68-76?"
Finally, doesn't this mean that pre '68 and post '68 cranks and transmissions don't mix?
Post Finally, I found this on my own hard drive and haven't located where I got it yet.
 Post subject: Hub and pocket....
PostPosted: Fri Apr 21, 2006 9:19 am
Up to 1967 has the small crank hub and pocket. From 1968 forward uses the larger pocket.
This means:
1)1968+ Engines can use any tranny, provided you have the correct flywheel for your crank, or use an annular pocket ring for the crank if using a pre-68 torque convertor .
2)Pre-68 engines can't accept late style torque convertors, you can either swap the crank to a post-67, or get a custom torque convertor (except in the case of the 1978+ Lock Up tranny which is post-67/big pocket only)
 Post subject: Re: Hub and pocket....
PostPosted: Fri Apr 21, 2006 10:34 am
This means:
Thanks.
Oops, I failed to specify that I'm looking about manual transmissions.
 Post subject: Re-edit...
PostPosted: Fri Apr 21, 2006 11:50 am
Early engine use a pre-68 flywheel...
Post-68 use a "late" flywheel...
Spend some $$$ and have a machinist make a ring so you can 'bush' a late flywheel to use on the early crank (not my first choice for the $$$).
 Post subject: Re: Re-edit...
PostPosted: Fri Apr 21, 2006 12:58 pm
Ack. I saw the word pilot and thought they were talking about the pilot on the end of the shaft. I hadn't paid attention to the actual measurements involved.
Apparently all end-of-shaft pilot bearings are the same?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 4 guests
