It is currently Mon Nov 23, 2026 6:36 pm
 Post subject: Idle Surge
PostPosted: Mon Apr 24, 2006 6:31 pm
Hey gang, I've been experiencing a deteriorating idle from the Swinger. I've been chasing what I assumed is/are vacuum leaks for what seems like forever, but they've never been so bad that the engine dies. It's always smoothed out when I've given it some gas.
BTW, it's a '72 Swinger, 225, Super Six and Dutra Duals since January, and a Pertronix conversion since '02. Otherwise stock.
Well, in the last few days, the idle has gotten noticeably worse, and it now has a peculiar surge that comes and goes. Does this still sound like a vacuum leak, or might there be something new?
I'm terrible at diagnosis, but what I have done is block each vacuum line from the carb and the two from the intake manifold, and there was no change. Any ideas? Thanks in advance!
VM
PostPosted: Mon Apr 24, 2006 7:22 pm
Have you adjusted the valve lash? Tight valves will give you that.
PostPosted: Tue Apr 25, 2006 12:07 am
Tight valves, yeah, you should check that. But could easily be a carburetor fault. What's the status of the carb?
PostPosted: Tue Apr 25, 2006 5:43 am
I'll check the valves this weekend, but I adjusted them a few weeks ago. I have a few adjusters that aren't as tight as the others, but I'm trying to hold off a while and replace all of them at once. Would tight valves come on so suddenly?
VM
PostPosted: Tue Apr 25, 2006 6:03 am
:oops: Okay, Dan, you got me. My carb is a <gasp!> rebuilt from National Carburetor, although it's worked pretty well thus far (since Jan 1). Before the conversion, I made a laughable attempt at rebuilding the BBD I got with my super six set-up, and determined that carb rebuilds are just out of my league. I wanted make sure I got an actual super six carb so that the choke would hook up properly, and my core was now an embarassing mess (and I wasn't even sure they'd accept it).
Assuming that the carb is the problem, why would a carb issue wait 4 months to rear its head? More importantly, is there any possible chance you could withhold the "I told'ja so"'s? :) I'll accept my spanking now...
VM
PostPosted: Tue Apr 25, 2006 8:45 am
Why would a carb problem wait four months...? Well, why does a fuel pump decide to fail when it does, instead of the week before or the day after? How come you notice the valves are loud enough to need adjusting while you're driving to work on Tuesday morning, instead of when you're driving home on Monday evening or in the grocery store on Wednesday afternoon...?
PostPosted: Tue Apr 25, 2006 10:14 am
Okay, Dan, okay. Just asking. You know you're one of my slant six heroes. Now, is anybody gonna walk me through diagnosing this, or have I made my bed and I now must lay in it?
I'm no mechanic. I've rebuilt an engine before, but the complexities of carbs and transmissions remain a mystery to me. I understand what they do in principle, but how they do it is magic. What do I check, how do I check it, and what will I need to do the checking? Or do I just assume that it's bad since it's rebuilt and ship it to one of the few "carb experts" left in the world and pay through the nose to have it properly rebuilt?
VM
PostPosted: Tue Apr 25, 2006 10:49 am
I'd recheck the valve clearance and give it a couple more thousandths to be sure before I did anything. After adjusting the valves put a vacuum gauge on the system and read it at idle and just off idle to see what change there is, probably none but check to be sure. If your vehicle has power brakes close the vacuum line and check as this can be the problem for sure.
I am new to this forum and I have never seen anyone write about the quirks of the Carter BBD but one problem I have with this carb is that the metering rods can get stuck momentarily by a very small piece of grit due to the small rod and jet as well as the stepup piston can grim up to make an off idle surge. Be sure to wiggle the throttle shafts to see if they are worn enough to be loosing vacuum. If you can adjust the valves you can pull the carb down enough to clean the fuel bowl and push the stepup system to see if it is moving freely, the hardest part is the keeping up with the ball bearings and linkages, got a digital camera? Try the valve and vacuum check first then play with the carb later, there can be a electrical bug too but I always save that fun for last.
Last edited by REDNECKMOBILE on Tue Apr 25, 2006 11:01 am, edited 2 times in total.
PostPosted: Tue Apr 25, 2006 10:51 am
You may want to try a quickie cleanout of the idle system to see if that'll get you going again. Get some good spray type carb cleaner, and with the engine running at a fast idle, put the plastic shooter straw into each of the two idle jets and give a good blast of cleaner. The idle jets are the screw-headed dinguses visible as you look down the carb throat. Then, with the engine held at a fast idle, remove the idle mixture screw (think there is only one on your Super Six carb) and shoot carb cleaner into the mixture needle screw. You will really have to rev the engine to keep it running with the screw removed.
Then, put the mixture screw back in, seat it gently (don't cram it down!), back it off 1½ turn, return the engine to a regular idle speed and proceed with idle mixture adjustment.
PostPosted: Tue Apr 25, 2006 4:27 pm
Thanks, guys. Okay, the valve adjustment will have to wait until the weekend when I have more time, but Dan, I sprayed the idle jets and both mixture screws (after removal) thoroughly with carb cleaner, engine running, per your instructions. No change.
It's really hard to describe what it's doing, but let me try again. I've had an erratic/rough idle to varying degrees for years. Sometimes I've been able to minimize it with valve adjustment, so I kinda feel like I can identify that problem. This feels very, very different. Yesterday, I set the idle a little higher to compensate for the current problem. As I come to a stop, the idle will begin a bit high, where it should be due to the idle setting. Then over the next few seconds, it's like something is intermittently dragging the engine's revs down. Occasionally, the engine is able to "break free" for a second or so, only to be pulled down again. Of course, each time the idle drops, it gets rougher.
It's definitely wierd, something I've never heard an engine do before. From my limited experience, it seems like the rough idle from my valve adj/vacuum leaks in the past have been "consistently erratic", if that makes any sense. This feels completely different. Maybe it is a crappy carb rebuild, but I'm betting they did a better job than I could've. At least if it comes to that, I've got a correct core.
Thanks for the help, guys. Any more ideas?
VM
PostPosted: Tue Apr 25, 2006 5:20 pm
Uhh, Dan, my Supersix BBD has two idle mixture screws, one for each barrel.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Apr 26, 2006 12:56 am
Idle screw count: I was guessing, since I couldn't recall what year they went to a single mixture screw. I am in Seattle at the moment, thousands of miles and an international border away from my library!
Idle deterioration: If this has been happening for years, i.e., since before you changed to the 2bbl setup, and through multiple valve adjustments, then it's probably not a carburetor or valve-related problem.
Does this occur only when the engine's hot (I'm thinking excessive heating of the fuel in the line between the fuel pump and carb—have you done the fuel line mod yet?)
What changes have you made to the ignition system in all these years during which you've had the problem?
PostPosted: Wed Apr 26, 2006 5:30 am
Sorry, let me clarify — the idle hasn't been getting steadily worse for years, it's just never been smooth. Usually I'll make it out and do a valve adjustment or find a vacuum hose leak, fix it, and it improves. Sometimes I worked on the assumption that it was an intake or exhaust manifold leak, and for me at least, int/exh removal installation is not a minor indertaking, so I live with it until I can justify it (like the super six conversion) or feel really ambitious. This idle issue came up relatively quickly, and just doesn't feel the same.
The idle was about the same before and after the super six conversion, which led me to believe that, once again, I just didn't get a perfect seal. Again, it hasn't been a terrible idle, just not smooth. The benefits of the 2bbl and exhaust were more than enough to make up for it until I could address the problem, though as I keep reiterating, diagnosis is my nemesis (maybe because it requires intellect).
Since before this problem, I've been gradually gathering parts to do the HEI conversion per your article, and I'm tempted to go ahead with it, just in case it is some sort of ignition problem. But I'm afraid it won't actually solve the problem, just mask it enough to live with. And I'd really like to figure this one out.
No, I haven't done the fuel line mod, because I've never had an issue that I could trace to boiling fuel (never a hot start problem, never ran worse when warm). And no, the idle issue is slightly worse when the engine is cold (although the choke seems to compensate somewhat).
The changes I've made over the years since the idle went rough have been: new plugs (3 sets), new plug wires (NOS Mopar), new distributor cap and rotor, new coil (stock), Pertronix conversion, a few new fuel and air filters, a water pump, rebuilt cylinder head, and, in Jan., the super six/dutra duals. I've checked the PCV, and it still rattles nicely.
The only other thing I can think of is that, after working perfectly for a few months, my choke has started dropping off too much when I touch the gas and knock it off high idle. I noticed the wire from the choke coil had broken off and I resoldered it last Sunday, but the problem continues. Probably that crappy rebuild, but I'm in Texas, so choke issues (especially until December) are low priority. Just though it could be related.
Thanks again. I'm listening...
VM
PostPosted: Wed Apr 26, 2006 7:21 am
VM
The charging system may be the problem, check altenator and battery to see if ignition is getting enough juice.
PostPosted: Thu Apr 27, 2006 6:04 am
Any more ideas/suggestions, or does everyone agree I have:
A) a vaccum leak
B) a badly rebuilt carb
C) misadjusted valves
D) a charging issue?
I'll try and check/adjust the valves Saturday, and drop by the 'zone to have them check out my charging system in the next day or so. If I don't find anything, I guess I'll pull the intake and send the carb off for a rebuild. Dan, who was that guy in CO you recommended? Can you provide his contact info (again)?
