It is currently Wed Nov 25, 2026 7:40 am
 Post subject: air shocks/pinion angle
PostPosted: Thu May 04, 2006 6:59 am
In reality on a daily driver 69 valiant, will rear air shocks pumped up pretty well affect the pinion angle enough to make the difference between a smooth ride when lowered and a vibration when pumped up? And if so, is this normal or a symptom of another issue? Thanks for the input.
PostPosted: Thu May 04, 2006 8:30 am
Rear air shocks are a good way to break a shock mount in the back. PO installed coilovers on my car before I got it. Result, a broken shock mount.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: not good
PostPosted: Thu May 04, 2006 8:58 am
Yeah, that's not a good thing. At this point, I'm on my third Valiant, a 67,68, and now 69. They've all had air shocks and I guess I've been really lucky as not to have had an issue with them until now, and that's only with a vibration I think is related to pinion angle. Maybe a good idea to keep em the pressure low then. Thnaks for the tip. Any idea on my original question though? Thanks!!!
PostPosted: Thu May 04, 2006 10:22 am
I would check the U joints and make sure they are in good shape. If not bad u joints could cause a vibration.
Pumped up air shocks decrease ride quality. Not sure how much pinion angle would change.
PostPosted: Thu May 04, 2006 1:58 pm
The rear shock mounts are not designed to carry a load such as they would have with coilovers or air shocks. The result is frequently the upper pins ripped out of the floorpan.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
