It is currently Mon Jun 22, 2026 7:51 pm
PostPosted: Wed May 03, 2006 3:21 am
http://www.tocmp.com/manuals/Carbs/Cart ... index.html
I've determined that the BBS and BBD carbs (depending on application) sometimes have the same step-up spring for the metering rod. So it looks like they're interchangable between the BBS and BBD.
However I didn't find any interchangability with the 4bbl carbs, but that doesn't mean you can't interchange them.
Just wondering if the Edelbrock step-up springs which you can get (and work in the 4bbl Carters) are interchangable with the BBD and BBS springs?????
