| Carter BBS and BBD step-up springs https://slantsix.org/forum/viewtopic.php?t=17380 |
| Author: | emsvitil [ Wed May 03, 2006 3:21 am ] |
| Post subject: | Carter BBS and BBD step-up springs |
From: http://www.tocmp.com/manuals/Carbs/Cart ... index.html I've determined that the BBS and BBD carbs (depending on application) sometimes have the same step-up spring for the metering rod. So it looks like they're interchangable between the BBS and BBD. However I didn't find any interchangability with the 4bbl carbs, but that doesn't mean you can't interchange them. Just wondering if the Edelbrock step-up springs which you can get (and work in the 4bbl Carters) are interchangable with the BBD and BBS springs????? |
