It is currently Sat Jul 18, 2026 12:39 am
 Post subject: New Moder likes da joos!
PostPosted: Sun May 07, 2006 7:34 pm
Went 13:51@98 on a 75 shot, motor hot.
Dialed 13:50 for the first round, motor cold. Spotted a Vette 2 full seconds. The instant I launched I knew I was in da poop. Flew past him at the 1/8th mile mark. Shut off the giggle gas after I went by, shut the motor off at 1000 feet, still went 13:17@86. It went 8:17@83 at the 1/8th. Mike's calculator said 12:96 for a full pull. :shock:
PostPosted: Mon May 08, 2006 6:50 am
Excellent! Should be no trouble hitting the 11s with a 150 shot, eh?
Keep up the good work,
PostPosted: Mon May 08, 2006 7:41 am
I'm hoping so Lou. It still ran in the 14:20's on motor only too. :shock:
PostPosted: Mon May 08, 2006 1:04 pm
What gears in the rear Zilla???
PostPosted: Mon May 08, 2006 1:17 pm
PostPosted: Mon May 08, 2006 5:32 pm
Car Model: 1964 Dart GT
Hey SlantZilla, I am new to SS forum and was wondering what upgrades you did to your motor. Sounds like it runs goooood!
PostPosted: Wed May 10, 2006 2:22 am
Your talking about the 'buzzin half duzzin' right? Isn't that your car. I saw it at vegas do 11's.
Cory
-'72 Valiant Sedan, Stock (For Now)
PostPosted: Wed May 10, 2006 4:16 am
Cory
Nope, that is Mike Jeffrey, I was the guy with him racing the rental car. :lol:
My junk is a '66 Valiant street car with a Mike Jeffrey motor. :D
Motor specs:
1970 198 block +.065" over
198 rods w/ARP rod bolts
2.2 turbo pistons
Mike Jeffrey head w/1.71 and 1.5 valves
Clifford .558" cam
Clifford intake
Clifford shorty headers
Holley 600 double pumper
2" carb spacer
Top Gun 75-150 nitrous plate system
ARP head stud kit
3" exhaust from Jeff's Custom Exhaust
This motor would be very easy to duplicate.
Trans is a 727specialists 904 w/V-8 guts, Griner trans brake, and a Midwest 8" nitrous converter.
Rear is an 8-3/4 w/ 3.91 Sure Grip and Moser axles
Front suspension is stock, rear is a pair of JC Whitney leaf springs w/Lakewood clamp-on slapper bars.
I have M/T ET Streets on Weld Drag Stars on the rear, Drag Stars and Radial T/A's on the front.
Car weighs 3250 w/me in it.
Other than the head, there is nothing fancy in the motor, the trans is way more trick.
You could duplicate this car with most any A-body, and with a 100 shot you would easily have a very reliable mid-12 second street car for well under $10K. :shock:
PostPosted: Fri May 12, 2006 6:17 pm
Did you use the 198 crank or a 225 crank?
Dart68
PostPosted: Sat May 13, 2006 3:38 pm
Steel 225. :shock:
PostPosted: Sat May 13, 2006 6:12 pm
Steel 225. :shock:
Any reason a 198 block? It is the same as a 225 block, isnt it?? If not, whats the difference?
AZ
PostPosted: Sat May 13, 2006 7:55 pm
Because I had one laying around. :lol:
The only diifference is the CI stamp, and my 232 says 198 on it. :shock:
PostPosted: Mon May 15, 2006 7:18 pm
Is the head and block shaved?? Stock Length pushrods??
PostPosted: Tue May 16, 2006 6:11 pm
Block and head were shaved just enough to make them flat. :D
Yes, I am using stock length pushrods. :shock:
PostPosted: Thu May 25, 2006 8:16 pm
What kind of rings, specifically the top compression rings are you using?
