| New Moder likes da joos! https://slantsix.org/forum/viewtopic.php?t=17458 |
Page 1 of 2 |
| Author: | slantzilla [ Sun May 07, 2006 7:34 pm ] |
| Post subject: | New Moder likes da joos! |
Went 13:51@98 on a 75 shot, motor hot. Dialed 13:50 for the first round, motor cold. Spotted a Vette 2 full seconds. The instant I launched I knew I was in da poop. Flew past him at the 1/8th mile mark. Shut off the giggle gas after I went by, shut the motor off at 1000 feet, still went 13:17@86. It went 8:17@83 at the 1/8th. Mike's calculator said 12:96 for a full pull. |
| Author: | Dart270 [ Mon May 08, 2006 6:50 am ] |
Excellent! Should be no trouble hitting the 11s with a 150 shot, eh? Keep up the good work, Lou |
| Author: | slantzilla [ Mon May 08, 2006 7:41 am ] |
I'm hoping so Lou. It still ran in the 14:20's on motor only too. |
| Author: | featherduster76 [ Mon May 08, 2006 1:04 pm ] |
What gears in the rear Zilla??? |
| Author: | slantzilla [ Mon May 08, 2006 1:17 pm ] |
3.91 |
| Author: | AndyZ [ Mon May 08, 2006 5:32 pm ] |
Hey SlantZilla, I am new to SS forum and was wondering what upgrades you did to your motor. Sounds like it runs goooood! |
| Author: | Hyper'72Valiant [ Wed May 10, 2006 2:22 am ] |
Your talking about the 'buzzin half duzzin' right? Isn't that your car. I saw it at vegas do 11's. Cory |
| Author: | slantzilla [ Wed May 10, 2006 4:16 am ] |
Quote: Your talking about the 'buzzin half duzzin' right? Isn't that your car. I saw it at vegas do 11's.
Nope, that is Mike Jeffrey, I was the guy with him racing the rental car. Cory My junk is a '66 Valiant street car with a Mike Jeffrey motor. Motor specs: 1970 198 block +.065" over 198 rods w/ARP rod bolts 2.2 turbo pistons Mike Jeffrey head w/1.71 and 1.5 valves Clifford .558" cam Clifford intake Clifford shorty headers Holley 600 double pumper 2" carb spacer Top Gun 75-150 nitrous plate system ARP head stud kit 3" exhaust from Jeff's Custom Exhaust This motor would be very easy to duplicate. Trans is a 727specialists 904 w/V-8 guts, Griner trans brake, and a Midwest 8" nitrous converter. Rear is an 8-3/4 w/ 3.91 Sure Grip and Moser axles Front suspension is stock, rear is a pair of JC Whitney leaf springs w/Lakewood clamp-on slapper bars. I have M/T ET Streets on Weld Drag Stars on the rear, Drag Stars and Radial T/A's on the front. Car weighs 3250 w/me in it. Other than the head, there is nothing fancy in the motor, the trans is way more trick. You could duplicate this car with most any A-body, and with a 100 shot you would easily have a very reliable mid-12 second street car for well under $10K. |
| Author: | DART68 [ Fri May 12, 2006 6:17 pm ] |
Did you use the 198 crank or a 225 crank? Dart68 |
| Author: | slantzilla [ Sat May 13, 2006 3:38 pm ] |
Steel 225. |
| Author: | AndyZ [ Sat May 13, 2006 6:12 pm ] |
Quote: Steel 225.
Any reason a 198 block? It is the same as a 225 block, isnt it?? If not, whats the difference?AZ |
| Author: | slantzilla [ Sat May 13, 2006 7:55 pm ] |
Because I had one laying around. The only diifference is the CI stamp, and my 232 says 198 on it. |
| Author: | featherduster76 [ Mon May 15, 2006 7:18 pm ] |
Is the head and block shaved?? Stock Length pushrods?? |
| Author: | slantzilla [ Tue May 16, 2006 6:11 pm ] |
Block and head were shaved just enough to make them flat. Yes, I am using stock length pushrods. |
| Author: | AndyZ [ Thu May 25, 2006 8:16 pm ] |
What kind of rings, specifically the top compression rings are you using? |
| Page 1 of 2 | All times are UTC-07:00 |
