It is currently Sat Nov 28, 2026 12:05 pm
PostPosted: Tue May 16, 2006 10:11 am
Car Model: Toad Wagon
Howdy,
Well, frustration at the growing list of small stuff I've been doing in lieu of the more important bits I want to be doing finally hit a peak. With some chronic fuel delivery problems at last deduced and corrected, Saturday I (at long last) popped on the "Super Six" I've had waiting in the wings for several months.
All in all a fun cobble, I'd butchered a thinwall one barrel aluminum manifold to mount a BBD turned sideways. That way I could keep Toad's torque shaft throttle linkage and it would yield a slightly more even intake distrubution as well.
At any rate, Here's a picture....
As usual the rest are in Yahoo. Use this '62 Super 6 or use the signature link and select the '62 Super 6 album.
(For those unused to Yahoo's photo stuff, the best pictures are in "view slideshow" mode with the progression stopped and run by hand.)
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Tue May 16, 2006 5:44 pm
Cool beans! How does she run?
PostPosted: Tue May 16, 2006 5:53 pm
Nice Work!!!!!!!!
Why do you want to move the alternator?
PostPosted: Tue May 16, 2006 6:04 pm
Nice work indeed! I didn't spot the referent on emsvitil's question about the alternator. Why'd you block off the heat riser?
More correct top radiator hose for your 225-equipped '62 is a Gates 20450.
PostPosted: Tue May 16, 2006 7:11 pm
Photo #34......... (he wants to move the alternator to the drivers side)
PostPosted: Wed May 17, 2006 5:23 am
very nice work. Congratulations!
Juan Ignacio Caino
PostPosted: Wed May 17, 2006 12:42 pm
Thanks gentlemen,
Got the 2 1/4" pipe and flow-through muffler in yesterday (looks like a sidewinder with sunstroke, not much room under a toad) to complete the package and the improvement in mid and top ranges is very pleasant. Scoots right on up to 100 now without complaining and holds open freeway speeds 75/85 (on those rare occasions traffic's running) comfortably.
The heat riser shunt is arched to echo the curve of the bottom side of the manifold throat (hopefully for a slightly better flow) and brazed in to seal it up without having to fuss with a gasket. Hand choking and just being in SoCal cover the warm-up process satisfactorily for me.
I'll move the alternator so I can run heater hosing to the inner fender and back from there more easily when I put the "in-cabin" heater/defroster in later in the year.
Some electrical changes and a bit more rear spring for toting things this year, and next year I should be able to get to the cosmetics.............and back to Cassi as well.
Dan, thanks for the hose ref, I'll go get one. I've made do with that one long enough.
Have fun........
Dick, 225% crazy.
PostPosted: Thu May 18, 2006 3:57 am
Dick,
The only thing I can say, is DANG, I wish we had hooked up when I lived 6 miles from you! Nice craftsmanship...
PostPosted: Sun May 21, 2006 12:57 pm
Car Model: 62 Lancer GT
Excellent job!!! What did you paint you're exhaust with?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Wed May 24, 2006 11:27 pm
I used some off brand high temp exhaust paint I had sitting around, and tossed the can when I emptied it so don't know which one to avoid. It's already looking like it'll want to be repainted before too long.
Finished up the project with the 2 1/4" pipes and flow-through muffler. Also decided to change the rocker box back from the Clifford to a tidied up stocker, looks more in keeping with the rest of the stuff.
Here're a couple clickable (I hope) pictures of each........
OK, guess I don't have that one down yet, so here're the references............
Headpipe, side view.
Headpipe, end view.
Rocker box, end view.
Rocker box, side view.
Dick, 225% crazy.
PostPosted: Mon May 29, 2006 7:13 pm
Thanks for posting the pics. I'm in the middle of a very similar project.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
