It is currently Sat Jun 13, 2026 4:43 pm
 Post subject: Gauges/dash?
PostPosted: Fri May 19, 2006 6:31 am
ok, I own A 68 Dodge Dart.. And I'm just not thrilled with the gauges that came from the factory, didnt come with a tac and I'm going to need a boost gauge for when I go turbo.
My question is What kind of dash (or hopfully just the insterment cluster)out of another mopar will fit in my old dart?
Or dose anyone know some place that sells inserts for my dart?
hopeing not to do much fabricaring..
I like the cars that go VROOOOOM
not the new ones that go wrrrrr -.-;
PostPosted: Fri May 19, 2006 7:02 am
www.rockymountaindashes.com made a gauge cluster for me:
http://mywebpages.comcast.net/pdevlin16 ... gauges.jpg
(I included it here as a link and not an embedded image so that I don't irk anyone with a 56k connection or 800x600 resolution or both.)
I'm using all VDO Vision gauges, except for the fuel gauge which is autometer. This cluster will require cutting the dash, though. There is someone who also makes a plastic insert more like the '70 A-body units (I think). Also a member on the board custom makes clusters from your old cluster. Try a search here.
Haven't gotten around yet to fitting these gauges...still need to buy my switches, actually.
'68 Dodge Dart 4dr Sedan
PostPosted: Fri May 19, 2006 7:33 am
Here's a bunch of gauges all in one unit:
http://store.summitracing.com/partdetai ... toview=sku
That might simplify things, if you don't want to fabricate.
PostPosted: Fri May 19, 2006 12:35 pm
sick 6 (member of this board) has his own custom gauge cluster business, check it out, it's a cheaper alternative to rockymountain dash.
70 Plymouth Valiant 4dr
