It is currently Mon Nov 23, 2026 1:00 pm
 Post subject: Removing 63 axle shaft
PostPosted: Tue Jun 06, 2006 1:56 pm
The 1963 factory svc manual (on p. 3-20) says:
"(1) With the wheel removed, remove the clips holding the brake drum on the wheel studs and remove the drum."
What do these clips look like and how are they removed?
It's a 7 1/4.
PostPosted: Tue Jun 06, 2006 2:10 pm
The Tinnerman Clips always got discarded the first time the drum needed removing. Don't worry about 'em.
PostPosted: Tue Jun 06, 2006 2:13 pm
Bummer. I thought I found the reason that I couldn't pull the drum off.
PostPosted: Tue Jun 06, 2006 2:23 pm
You can't pull the drum off 'cause the shoes are hanging up on the unworn lip at the mouth of the drum. You'll have to go in through the adjustment access slots and back the adjustors off so the shoes contract and allow the drum to be removed.
PostPosted: Tue Jun 06, 2006 2:26 pm
or use a wrecking bar, and rip the darn drums off.
(My way, but not recommended for casual use or repair)
PostPosted: Tue Jun 06, 2006 3:05 pm
Might not be the shoes.
Occasionally you get a rust weld in the center hub.........
