It is currently Mon Nov 23, 2026 10:33 am
 Post subject: removing hub from drum
PostPosted: Tue Jun 06, 2006 10:52 pm
did anyone remove the hub from the front 10" brake drum?
should I hammer on the hub with the drum on 2 wood or remove the extra metal on
the wheel stud near the drum and pull the drum off.
PostPosted: Tue Jun 06, 2006 11:17 pm
The studs have to come out first. The studs hold the drum to the hub very well.
PostPosted: Tue Jun 06, 2006 11:31 pm
There's a little swedge over the stud holding the drum on. You need to cut the swedge off
PostPosted: Wed Jun 07, 2006 11:45 am
all right guys, Thank you for your help
PostPosted: Wed Jun 07, 2006 11:50 am
I took off the heads by drilling the center with 1/2" bit and then using a chisel.
All other methods of removing the head are preferable, unless you don't mind ruining drill bits.
Looking at the five I removed this week, the swaged part of the stud that is flared out can be 1/8" long.
If you have a way to cut the swage off, you need to cut about 1/8" deep.
