| removing hub from drum https://slantsix.org/forum/viewtopic.php?t=17934 |
| Author: | makapipi [ Tue Jun 06, 2006 10:52 pm ] |
| Post subject: | removing hub from drum |
did anyone remove the hub from the front 10" brake drum? should I hammer on the hub with the drum on 2 wood or remove the extra metal on the wheel stud near the drum and pull the drum off. |
| Author: | Joshie225 [ Tue Jun 06, 2006 11:17 pm ] |
The studs have to come out first. The studs hold the drum to the hub very well. |
| Author: | emsvitil [ Tue Jun 06, 2006 11:31 pm ] |
There's a little swedge over the stud holding the drum on. You need to cut the swedge off |
| Author: | makapipi [ Wed Jun 07, 2006 11:45 am ] |
all right guys, Thank you for your help |
| Author: | sixsignet [ Wed Jun 07, 2006 11:50 am ] |
![]() I took off the heads by drilling the center with 1/2" bit and then using a chisel. All other methods of removing the head are preferable, unless you don't mind ruining drill bits. Looking at the five I removed this week, the swaged part of the stud that is flared out can be 1/8" long. If you have a way to cut the swage off, you need to cut about 1/8" deep. |
