It is currently Sun Nov 22, 2026 9:11 am
PostPosted: Fri Jun 09, 2006 10:02 am
Hi everyone, i'm going to machine my own shackle bushings out of delrin (by the way, won't it be too hard? Do you think it will allow enough play. Can rubber be machined in a conventional lathe?) so I'm in search of the dimensions. Do you have an approximate length (not too critical right?) and the precise outside diameter? The inside is 1/2" right?
Thanks for your help
Marc
PostPosted: Fri Jun 09, 2006 12:51 pm
Marc
Darn near as hard as iron.
Dip rubber in liquid nitrogen to machine it. I know guys who just freeze it overnight in a deepfreeze, but it doesn't stay hard long.
PostPosted: Fri Jun 09, 2006 2:03 pm
Where could I find liquid nitrogen!!!? :shock:
PostPosted: Fri Jun 09, 2006 6:31 pm
Wish I could tell you.
PostPosted: Sat Jun 10, 2006 2:23 am
Does anybody have some bushings not yet mounted to measure it?
Pleaaaase! :D
PostPosted: Sat Jun 10, 2006 4:02 am
You were one day late with your request. I just returned a set of bushings. The large spring eye is 1 3/8 inch (nominal), I did mike the od of the bushing, but forget what it was. I am refering to a 66 "A" body, a different body style might be different.
PostPosted: Sat Jun 10, 2006 6:25 am
They are like 3 dolars at a parts store. Then you hve something to copy.
________
Buy Vaporizer
________
Female advice advice
PostPosted: Sat Jun 10, 2006 7:29 am
For an early "A" body, no one had them on the shelf. had to order thru NAPA. $50 for a complete rear spring bushing set ( 2 front bushings, and 8 shackel bushings).
PostPosted: Sat Jun 10, 2006 11:00 am
NAPA seems to have a way with prices. They wanted $35 for a '65 Valiant master cylinder and $65 for a repair kit for one.
PostPosted: Sat Jun 10, 2006 2:17 pm
It's really more complicated than this, this side of the ocean... :wink:
P.S : it's for a '67 Dart
PostPosted: Mon Jun 19, 2006 5:10 pm
Come on guys, can anyone measure the small eye diameter? I'm gonna machine them out of delrin, a friend of mine told me it was not harder than polyurethane, so... Even if it's not the best choice for comfort, at least i will have something to put in my shackles! :lol:
I guess i should machine them a few 10ths more than the spring eye to make it tight, right?
Marc
