| Shackles bushings length/diameter. https://slantsix.org/forum/viewtopic.php?t=17973 |
| Author: | marc426 [ Fri Jun 09, 2006 10:02 am ] |
| Post subject: | Shackles bushings length/diameter. |
Hi everyone, i'm going to machine my own shackle bushings out of delrin (by the way, won't it be too hard? Do you think it will allow enough play. Can rubber be machined in a conventional lathe?) so I'm in search of the dimensions. Do you have an approximate length (not too critical right?) and the precise outside diameter? The inside is 1/2" right? Thanks for your help Marc |
| Author: | RossKinder [ Fri Jun 09, 2006 12:51 pm ] |
| Post subject: | Re: Shackles bushings length/diameter. |
Quote: Hi everyone, i'm going to machine my own shackle bushings out of delrin (by the way, won't it be too hard?
Darn near as hard as iron.Marc Dip rubber in liquid nitrogen to machine it. I know guys who just freeze it overnight in a deepfreeze, but it doesn't stay hard long. |
| Author: | marc426 [ Fri Jun 09, 2006 2:03 pm ] |
Quote: Dip rubber in liquid nitrogen
Where could I find liquid nitrogen!!!? |
| Author: | RossKinder [ Fri Jun 09, 2006 6:31 pm ] |
| Author: | marc426 [ Sat Jun 10, 2006 2:23 am ] |
Does anybody have some bushings not yet mounted to measure it? Pleaaaase! |
| Author: | Charrlie_S [ Sat Jun 10, 2006 4:02 am ] |
You were one day late with your request. I just returned a set of bushings. The large spring eye is 1 3/8 inch (nominal), I did mike the od of the bushing, but forget what it was. I am refering to a 66 "A" body, a different body style might be different. |
| Author: | 74.swinger [ Sat Jun 10, 2006 6:25 am ] |
They are like 3 dolars at a parts store. Then you hve something to copy. ________ Buy Vaporizer ________ Female advice advice |
| Author: | Charrlie_S [ Sat Jun 10, 2006 7:29 am ] |
Quote: They are like 3 dolars at a parts store. Then you hve something to copy.
For an early "A" body, no one had them on the shelf. had to order thru NAPA. $50 for a complete rear spring bushing set ( 2 front bushings, and 8 shackel bushings).
| Author: | RossKinder [ Sat Jun 10, 2006 11:00 am ] |
Quote: Quote: They are like 3 dolars at a parts store. Then you hve something to copy.
For an early "A" body, no one had them on the shelf. had to order thru NAPA. $50 for a complete rear spring bushing set ( 2 front bushings, and 8 shackel bushings). |
| Author: | marc426 [ Sat Jun 10, 2006 2:17 pm ] |
It's really more complicated than this, this side of the ocean... P.S : it's for a '67 Dart |
| Author: | marc426 [ Mon Jun 19, 2006 5:10 pm ] |
Come on guys, can anyone measure the small eye diameter? I'm gonna machine them out of delrin, a friend of mine told me it was not harder than polyurethane, so... Even if it's not the best choice for comfort, at least i will have something to put in my shackles! I guess i should machine them a few 10ths more than the spring eye to make it tight, right? Thanks for your help Marc |
