Tie Rod Ends - Installation.
https://slantsix.org/forum/viewtopic.php?t=18022
Author:  bwhitejr [ Mon Jun 12, 2006 10:30 am ]
Post subject:  Tie Rod Ends - Installation.
To install tie rod ends and control arm bushings (upper and lower) do you need special tools? How is it done?
bwhitejr
Author:  imnoisydart [ Thu Jun 15, 2006 12:11 pm ]
You need a pickle fork to whack the ball joints out.
They are cheap andavailable at any auto parts place.
What I like better are the special tool (available from
Just Suspension among others that basically is a bolt
in a retainer that presses the joint out as you turn the bolt.
Author:  bwhitejr [ Mon Jun 19, 2006 8:58 am ]
To put the tie rod ends back on, you just keep turning the nut till it reaches the proper torque setting?
bwhitejr
Author:  74.swinger [ Mon Jun 19, 2006 6:48 pm ]
I use a ball joint press to install the control arm bushings . I use an air chisel to remove them.
________
Volcano digital vaporizer
________
Zx14 Vs Hayabusa
Author:  sixsignet [ Tue Jun 20, 2006 8:13 pm ]
Post subject:  Re: Tie Rod Ends - Installation.
bwhitejr
I'd like to know the answer to this, including idler arm.
Author:  Matt Cramer [ Wed Jun 21, 2006 5:42 am ]
bwhitejr
Yes, that's exactly how they work.
And if you get a pickle fork, be sure to buy a unit that was made entirely in one piece. I bought one that apparently had a business end made from bar stock welded onto a hollow tubular handle. It lasted just long enough to get all the items on my suspension pulled before the weld shattered and the handle came off. :roll:
