It is currently Sun Nov 22, 2026 3:10 am
PostPosted: Mon Jun 12, 2006 10:30 am
To install tie rod ends and control arm bushings (upper and lower) do you need special tools? How is it done?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Jun 15, 2006 12:11 pm
Car Model: 69 Dart Slant 6
You need a pickle fork to whack the ball joints out.
They are cheap andavailable at any auto parts place.
What I like better are the special tool (available from
Just Suspension among others that basically is a bolt
in a retainer that presses the joint out as you turn the bolt.
PostPosted: Mon Jun 19, 2006 8:58 am
To put the tie rod ends back on, you just keep turning the nut till it reaches the proper torque setting?
bwhitejr
0.090 Shaved Head
PostPosted: Mon Jun 19, 2006 6:48 pm
I use a ball joint press to install the control arm bushings . I use an air chisel to remove them.
________
Volcano digital vaporizer
________
Zx14 Vs Hayabusa
PostPosted: Tue Jun 20, 2006 8:13 pm
bwhitejr
I'd like to know the answer to this, including idler arm.
PostPosted: Wed Jun 21, 2006 5:42 am
bwhitejr
Yes, that's exactly how they work.
And if you get a pickle fork, be sure to buy a unit that was made entirely in one piece. I bought one that apparently had a business end made from bar stock welded onto a hollow tubular handle. It lasted just long enough to get all the items on my suspension pulled before the weld shattered and the handle came off. :roll:
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
