It is currently Thu Nov 26, 2026 2:16 am
 Post subject: super six!
PostPosted: Mon Jun 12, 2006 4:32 pm
Car Model: 1967 Dodge Dart GT
hey guys, posted a few days ago about a super six and aluminum 1 bbl at the local yard, got the whole super six setup, off of a volare that was driven into the yard, and an aluminum 1 bbl off a d 150, whole kit n caboodle for 43 bucks(inc. tax) so i think i should be able to do this based on the article on the main site, but i cant understand if i need the throttle cable off that or not, the car it is going onto is a 67 dart gt, thanks!
PostPosted: Mon Jun 12, 2006 4:40 pm
For a direct swap, you'd need a V8 throttle cable to suit your '67 Dart.
PostPosted: Mon Jun 12, 2006 4:54 pm
thats what i was afraid of, no way to make the current one work? will the one from the donor volare work? thanks!
PostPosted: Mon Jun 12, 2006 4:57 pm
The one form the VOlare will work, but if I remember right your 67 should have a cable style throttle lnkage. THis will work so long as you drill out the little hole at the end of the cable.
PostPosted: Mon Jun 12, 2006 5:01 pm
The one from the Volaré will work once you modify the firewall hole (early cars like yours have a round metal ferrule at the firewall end of the throttle cable; later cars like the Volaré have a larger square plastic ferrule.
The existing cable is too long; if you loop or coil it to connect to the 2bbl attaching point, it'll bind.
PostPosted: Mon Jun 12, 2006 5:19 pm
ok, thanks guys, looks like a trip back to the parts yard is in order, wish it wasnt 45 mintues away :lol: i think ill try to do this swap next weekend, i gotta work saturday this weekend, usually i dont, so that will give me time to get that cable and another check to go towards the new 2.25 exhaust :twisted:
PostPosted: Wed Jun 21, 2006 9:46 pm
dan, my 1bbl. cable fit just fine with the loop and did not bind
1975 Plymouth Duster,225/6 2bbl. and duels, 904, 7 1/4
1986 Dodge Charger Shelby, 2.2 Turbo I, A525
PostPosted: Thu Jun 22, 2006 6:27 am
You might want to rebuild that carb while you are waiting for the cable. When I put the 2 bbl on my '69, I ended up using the cable from the '69 1bbl somehow or the other. If you have an auto tranny, you will want the tranny kick down linkeage. I had to splice the tranny end from my '69 to the carb end of the volare link. I did this with a threaded rod union, and cut and tapped both rods to fit the union. A lock nut is needed to keep it in adjustment. This arrangement gives you another kick down adjustment, which is more convenient than going down under the car.
