It is currently Sun Nov 22, 2026 2:27 pm
PostPosted: Wed Jun 14, 2006 5:13 pm
I have a 74 big bolt pattern rear that I am going to swap into a 71 Swinger. The car is out of state in storage so I cannot go look at it. The 72 - 76 rear brake hose has a tee built into it. The new 70 - 71 hoses I have looked at do not. Does anyone know if the hose attachment point on the body is the same from 70 -76? If it is I will just go with the later style hose and use the matching steel lines on the later rear end. I am trying to get the new rear end prepped so I can ship it out to where the car is and it will be a quick swap when I get there without having to chase down parts in a fairly rural area.
PostPosted: Fri Jun 16, 2006 2:18 pm
I put a rear axle from a '75 into my '65 and didn't have a problem with the brake hoses. So I don't see why you would have any problems.
