| A body rear brake hose. 70 - 71 verses 72-76 https://slantsix.org/forum/viewtopic.php?t=18068 |
| Author: | AnotherSix [ Wed Jun 14, 2006 5:13 pm ] |
| Post subject: | A body rear brake hose. 70 - 71 verses 72-76 |
I have a 74 big bolt pattern rear that I am going to swap into a 71 Swinger. The car is out of state in storage so I cannot go look at it. The 72 - 76 rear brake hose has a tee built into it. The new 70 - 71 hoses I have looked at do not. Does anyone know if the hose attachment point on the body is the same from 70 -76? If it is I will just go with the later style hose and use the matching steel lines on the later rear end. I am trying to get the new rear end prepped so I can ship it out to where the car is and it will be a quick swap when I get there without having to chase down parts in a fairly rural area. |
| Author: | kesteb [ Fri Jun 16, 2006 2:18 pm ] |
I put a rear axle from a '75 into my '65 and didn't have a problem with the brake hoses. So I don't see why you would have any problems. |
