It is currently Fri Nov 27, 2026 4:04 am
 Post subject: Carb Spacer for BBD
PostPosted: Fri Jun 23, 2006 8:41 am
Is there a carb spacer made for the BBD? How much good does one do? I'd like to improve my mileage and performance a little. Currently running a super six set up w/ a 727 in a D100. Also have Chrysler electronic ignition, two and a quarter inch exhaust.
Thanks,
Joe
Joe Hoppe
PostPosted: Fri Jun 23, 2006 9:18 am
I have never seen one specifically for a BBD, but you can find them for a Holley 2300 and then run an adapter to go from the BBD pattern to the 2300 pattern then back to the BBD pattern. Or you could sandwich two adapters. Or do like I did and make your own out of flat iron. There's lots of options, but nothing pre-made exactly to fit.
PostPosted: Fri Jun 23, 2006 9:27 am
Car Model: 1967 Dodge Dart GT
hey, i was also wondering about the other part of his question, "how much good does it do?" i have also put on a super six recently and i thought that a spacer hurt mileage and performance? i bought a rebuild kit at napa and it came with a spacer, when i rebuild, should i put it on? thanks
PostPosted: Fri Jun 23, 2006 9:43 am
It came with a spacer? Are you sure it isn't the correct thicker carb base gasket? I have always heard that spacers have been proven to increase torque and gas mileage.
PostPosted: Fri Jun 23, 2006 9:46 am
How thick of a spacer are you after? You can stack up the insulated 3/8" thick carb base "gaskets" (which are actually spacers) to get whatever thickness you want...
PostPosted: Fri Jun 23, 2006 11:09 am
OK, thanks everybody for answering part of the question. I'd still like to know how much difference one would make.
Anybody used one? What is a good thickness?
Joe
Joe Hoppe
PostPosted: Fri Jun 23, 2006 1:02 pm
lol, yeah, its probably a gasket, i thought it was a spacer though, but what difference doe sit make?
PostPosted: Tue Jun 27, 2006 3:17 pm
I traced out and measured a used gasket I had for my Carter BBD. I bought a sheet of delrin and had a machinist at work cut it out for me. I got the idea from argentina-slantsixer who did it with a delrin/zytel sandwich on his 1 barrel. I ended up taking mine off because it only treated the symptom of a problem I had, which was too much heat getting to the carb. Hindsight, a better design would have looked at the manifold and carb openings for more exact measurments. As for benefits? I couldn't tell you beyond heat shielding.
Users browsing this forum: No registered users and 34 guests
