| Spindle matching https://slantsix.org/forum/viewtopic.php?t=18348 |
| Author: | RossKinder [ Sun Jul 02, 2006 11:58 am ] |
| Post subject: | Spindle matching |
A pre-'73 B-body spindle will bolt up to A-body control arms, if you first put in a '73 plus A-body top ball joint. Did I get it right? |
| Author: | RossKinder [ Wed Jul 05, 2006 5:35 am ] |
| Post subject: | Re: Spindle matching |
Quote: A pre-'73 B-body spindle will bolt up to A-body control arms, if you first put in a '73 plus A-body top ball joint.
Did I get it wrong?
| Author: | slantvaliant [ Wed Jul 05, 2006 6:16 am ] |
I don't know about the pre-73 B spindles. I've only recall references to the post-73 BFMJ spindles. To use those in an A-body (understanding the different opinions on that matter), you should use '73-up A-body A-arms which accept the larger balljoints. |
| Author: | Matt Cramer [ Wed Jul 05, 2006 8:46 am ] |
No. You must use '73-'76 control arms or aftermarket tubular units, unless you want to do some very creative modifications to the pre-'72 control arms.Did I get it right? Lower ball joints fit in with no problem. |
| Author: | RossKinder [ Wed Jul 05, 2006 10:50 am ] |
Quote: Quote: A pre-'73 B-body spindle will bolt up to A-body control arms, if you first put in a '73 plus A-body top ball joint.
No. You must use '73-'76 control arms or aftermarket tubular units, unless you want to do some very creative modifications to the pre-'72 control arms.Did I get it right? Lower ball joints fit in with no problem. When did B-bodies start getting discs? Thanks |
| Author: | RossKinder [ Sat Jul 08, 2006 1:02 pm ] |
Quote: You must use '73-'76 control arms or aftermarket tubular units, unless you want to do some very creative modifications to the pre-'72 control arms.
WHOA! What did they do to me?OK, the yard where I got some front end stuff pulls the parts for you. You can't even get into the yard yourself. I think they must have given me B-body upper arms - a width of 11"? I hardly looked at them until I got home. To get the bigger/newer ball joints I need '73 plus A-body UCA's? Is that how it goes? E-body won't work? I think maybe they broke a bolt trying to get a UCA out of an E-body and went after a B-body instead. The Mopar guy there is pretty good, but I think he's forgot a lot. TIA |
