It is currently Sat Nov 21, 2026 3:24 am
 Post subject: Spindle matching
PostPosted: Sun Jul 02, 2006 11:58 am
A pre-'73 B-body spindle will bolt up to A-body control arms, if you first put in a '73 plus A-body top ball joint.
Did I get it right?
 Post subject: Re: Spindle matching
PostPosted: Wed Jul 05, 2006 5:35 am
Did I get it right?
Did I get it wrong?
PostPosted: Wed Jul 05, 2006 6:16 am
I don't know about the pre-73 B spindles. I've only recall references to the post-73 BFMJ spindles. To use those in an A-body (understanding the different opinions on that matter), you should use '73-up A-body A-arms which accept the larger balljoints.
PostPosted: Wed Jul 05, 2006 8:46 am
Did I get it right?
No. You must use '73-'76 control arms or aftermarket tubular units, unless you want to do some very creative modifications to the pre-'72 control arms.
Lower ball joints fit in with no problem.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Jul 05, 2006 10:50 am
Did I get it right?
So the A-body uppers have to be '73 plus to make it work,
When did B-bodies start getting discs?
PostPosted: Sat Jul 08, 2006 1:02 pm
WHOA! What did they do to me?
OK, the yard where I got some front end stuff pulls the parts for you. You can't even get into the yard yourself.
I think they must have given me B-body upper arms - a width of 11"? I hardly looked at them until I got home.
To get the bigger/newer ball joints I need '73 plus A-body UCA's? Is that how it goes? E-body won't work? I think maybe they broke a bolt trying to get a UCA out of an E-body and went after a B-body instead. The Mopar guy there is pretty good, but I think he's forgot a lot.
TIA
