It is currently Wed Dec 31, 2025 11:53 am
 Post subject: Swapping 170 for 225
PostPosted: Mon Jul 03, 2006 12:22 pm
i read that the cranks are different the 170 was automatic,and the 225 is a three speed, i want to keep the auto matic... anyone know if it will be a straight swap or do i need to buy some parts?
PostPosted: Mon Jul 03, 2006 12:47 pm
What model year are both engines?
PostPosted: Thu Jul 06, 2006 12:13 pm
sorry it took so long to respond i gotsta go to the library too get online.
the 170 is a 1966, and the 225 is 70 something, i read that i'll need to get a bushing, but am not sure if i need to change bell housings or anything else. I'd like to keep the original trans in the 66.
PostPosted: Thu Jul 06, 2006 12:39 pm
Yep, you need the spacer bushing so the '66 torque converter is properly suppored and centered in the larger pilot hole of the later engine. Other than that and a little work to the exhaust down-pipe you'll be fine.
Where are you located? I'm looking for a 170 core to rebuild.
PostPosted: Thu Jul 06, 2006 2:07 pm
You'll need a 225 flexplate, spacer as joshie said. I just finshed doing a 77-225 auto into a 64 170 auto spot in a Valiant. I left the trans in the car. but many pull them togather. This site got me through it and all I had to fear was fear itself. Let me know if I can lend moral support.
Users browsing this forum: No registered users and 20 guests
